Hello Fellow Hunter Owners,
Recently we purchased a Hunter 26 Water Ballast sailboat. We love the boat but have had a few difficulties and could use a bit of assistance.
First, we are having some difficulties with water accumulating in the boat during heavy downpours. The bilge pump did not appear to work properly and water collected iin various areas of the inside of the boat. In an attempt to soder wires to reconnect the bilge wires, we noted the wires continued to get very hot. Is there some type of special wiring on this boat that would cause this? The bilge pump appears to be located in an area above where the water collected. Is there an easy solution to relocatiing the bilge pump where it might be more effective?
The sealed windows appear to have some leakage. Can anyone provide instuction on how to re-seat these areas?
Next, we are considering a self furler, but are confused as to which product would best suit the boat and our needs. We are casual sailers on a small lake.
Any thoughts or advice on the above would be highly appreciated.
Thank you.
Thank you.
