Mystery Wire
Steve Franklin
While rewiring my electical panel, one of the wire labels disappeared. Now I have a "spare" green wire that comes from the same bundle that is wired to the original Catalina switch panel (master, cabin lt, running lt, spreader lt, anchor lt, bow lt.) Does anyone know what the green wire goes to? Unfortunately, all positions are filled by an appropriately labeled wire, so it's not just a case of finding the "empty" switch terminal. Murphy strikes again!! Thanks in advance.
Tom Soko
Ground Wire?
Most likely the green wire is a ground wire for one of your lighting systems. Have you tired using a multi-meter to test continuity?
G
greg
HIGH VOLTAGE!
I love the sound of high voltage crackling! Got your attention eh? Except in house wiring where color codes are strictly adhered to by licensed electricians, boat wire color is mostly by whim of the installer. If you have experience in wiring, tracing the green wire is a no brainer because you can use a multimeter to trace wires. However, if you only have a limited understanding of wiring I can offer a few suggestions: 1)leave the green wire disconnected, attach your battery and turn on all you switches. If everything works "ferget about it". Otherwise, what does not light up or work may be the clue you need to identify the wire. 2)if after turning on all your circuits and SEVERAL or all circuits do not work, then possibly the green wire is a return (or ground, or common, all the same) to the negative side of the battery. I relocated and rewired the fuse panel of my Cat 22 but I forgot what all the colors were, in any event they did not seem to make sense to me at the time. However, if I recall correctly, BLACK was used as the common or return or negative side of the circuit (ie battery negative). If you have fused everyting, don't be affraid to experiment (fuses are cheap). If you can supply more clues, I could be of more help.
