Mystery space - 37
davidm
Feb 24, 2004
15
- - Toronto
There is an enclosed space on the starboard side of the cabin. It is at the starboard side of the companionway against the hull, aft of the nav table, and is enclosed by pannelling. It measures about a foot square. The legend on the plan in the O'Day manual gives a description, but is not legible. Can anyone explain what is inside it, if anything?
Barrett
I dunno
haven't a clue..is yours a center cockpit ,as well?..If you find out let me know.
O
Olivier Ruhlmann
On the large ice box model...
On the 37 model that came with the large ice box instead of the nav station this whole space is occupied by the ice box... So I doubt that there is anything critical behind you nav station.
Jun 16, 2004
2
Oday 37 Titusville
Access panel for wiring
The spacecan be used to run wiring and for access to the back of instruments installed in the panel over the nav station.
davidm
Feb 24, 2004
15
- - Toronto
mystery solved
Thanks, I was looking for somewhere to run some wiring . I will hopefully be passing Titusville sometime in late November/early December en route from Toronto to Miami. Where do you keep your boat? David Marrison
