Dean Strong
Peggy,We bought a 1990 Hunter 30 in March thatwas really dirty, and have been cleaning, cleaning, cleaning ever since...Just about finished, but have this lingering odor in the head. It is a sweet smell, like room deodorizer or something.I have read all of your articles and have cleaned all of the mildew (was lots of it) on the inner liner of the hull, pulled the cabinet facings clear off, cleaned there too...In fact just sprayed everything with a 10 percent bleach solution. Have been using KO and CP, so head and tank smell fresh and clean. Head lines run under rear transverse double berth, so we removed structure, and cleaned down to the hull, around holding tank, hoses, is sparkling clean.Bilge is sparkling clean too. Have a dripless system, so there is never any water in the bilge, and you could eat out of it. Don't know where else to look for where this odor is coming from, except under the pan. For instance, I'm not sure where the shower drains to.. eventually the bilge, but is it in the space between the fiberglass pans under each of the floor boards (I have removed all of those too, cleaned, and and replaced wood screw plugs)?There is a solar vent in the head, that runs a fan all of the time. When the head door is left open, the odor is not noticeable. But when the door is left closed (even for just 30 minutes or so), the odor is pretty strong.Any ideas?
