I found water salt water in the bilge today for the second time in two weeks--about half an inch (a gallon overall), not enough for the float switch to activate the pump. I was on the boat for a week, and it was dry at the beginning of the week, and I never heard the pump come on (and I test it every time the boat is used).
I've had fresh water many times in the bilge, and have traced this leak to the screws securing the steering radiant cover. But I've never had salt water in the bilge before . . . and yes, I know it is salt water, because I purchased a Seatest aquarium floating arm tester a few years ago from my local pet store, so I could always tell if bilge water was fresh or salty.
What's strange about this water is that its sality is higher than the gauge will measure. Seawater in the Pacific Northwest is about 33 ppm; this water goes off the gauge at plus 40.
Its also bown/rust colored. When rain water finds its way into the bilge, it is pretty clear, except for the cloudiness from whatever crud is growing inbetween hull and the pan liner.
Seems like leaking thru-hull or weeping keel bolt should also be clear, not rust colored.
The area directly under the engine is dry, so its not the PSS shaft seal, or raw water intake thru-hull or hose.
All other thru-hulls are closed.
There is an antisiphon valve on the raw water line before it enters the mixing elbow. A tube runs from the this valve around the top of the engine cabinet, into an opening in the engine mount stringers. Anyone have trouble with this?
The boat gets used often, so I'm pretty sure this is not water that has accumulated in the liner, and has found its way into the bilge from heeling, etc.
Muffler? Any other ideas?
