My YSM 8 on my 25 MkII here in Annapolis was worked on recently. An exhaust elbow was replaced and the idle was adjusted.
WHen I run the motor while tied up, after warming it up for 5 minutes or so, I put in forward and reverse for very brief periods, just to check that the prop engages.
I end up with some white smoke in the exhaust (which the manuals say is OK, under load) and some black fluid coming out of the same exhaust. Not sure if this is oil or partially burnt fuel.
The black stuff leaves marks down my transom.
Is this normal when the prop is engaged and is slightly straining while the boat is tied to the slip?
My diesel mechanic wants to check the boat (a quick haul out) for a fouled prop. While I trust my guy, I saw this boat before it went into the water in late Feb. The cutlass bearing had a little play in in it when it was surveyed but other than that it looked fine.
