My VC Tar is GONE!!!!!!!
27
- - Racine, WI
I have an '88 Hunter 28.5 with the iron keel that has some sort of white (epoxy?) coating on it. Last fall, I cleaned off all the paint, filled in the few rust spots. Sanded, de-waxed like 5 times (no water beading) then applied 4 coats of VC Tar, about 3-4 hours drying time between coats. Let it dry 3 days (60+ degrees each day), then applied 2 coats of Micron CSC. I put her in Lake Michigan in May and just took her out today. Imagine my surprise when they powerwashed the bottom and althe VC Tar was gone! The power washng didn't remove it..it was just gone! Wha' happened???? Anyone else ever have this happen? The yard guy said that, since there's no rust showing, I should just paint it and forget it. But I'd like to know why the VC Tar disappeared. As an aside, I did the rudder at the same time as the keel, and the VC Tar and the paint stuck. Hmmm!
