My Life With A 1984 Catalina 36, M-25 AND OIL LEAK
Aug 3, 2014
68
CATALINA, BENETEAU OCEANIS 36, 400 Grosse Ile, Mi and Fajardo, PR
Living The Dream On A Cat 36, Help With Bimini And Oil Leak
Hello All,
I purchased my 1984 Catalina 36 with a Universal M-25 in June 2014. My punch list is progressing, slowly. I wish to share a few thoughts:
1.) I purchased two items from Harbor Freight, a rotary variable speed 7" buffer and a variable speed 6" dual action buffer. I used a wool pad on the 7" to apply 3M Heavy duty rubbing compound. I applied the wax/polish with the 6" using a foam pad. I used New Finish on the hull and Meguiare's cleaning wax on the top sides and cockpit. I believe the Meguiare's did a better job. The boat looks great!
2.) Sanded, bleached and varnished the teak. I Used Epifanes Gloss Clear. It turned out nice.
3.) I am in the process of replacing the 10 awg orange wire from the alternator B+ to the ammeter returning on the red 10 awg to the starter B. Many of you are aware Maine's simple fix is to jump the B+ to the B with 4 awg or bigger. I had a single set of trailer plugs wrapped in electrician's tape. The trailer plug was bad, bad and bad. I used Ancor heat shrink butt connectors to replace the trailer plug. The trailer plug was causing starting problems. I had hoped to replace the copper wire with tinned wire, however, I found it is impossible to push the wire through some areas in the hull. In the future, I hope to sacrifice the orange wire and use it to pull the tinned wire through the difficult hull areas.
4.) Today, I noticed the secondary fuel filter bracket was broken. It was ok when I replaced the filter this spring. I searched this site and found this is a common problem. Toad ( previously, Torrensen) has them for about $ 30.
5.) I have had a few deck leaks, including the port cap shroud. I used Maine's butyl tape and it works well.
QUESTION:
1.)The Universal M-25 leaks about 1/2 oz of oil per hour. It appears to be coming from the oil pan seal, dip stick seal and valve cover seal. Mostly, 4 bolts on the oil pan seal. I would appreciate your thoughts on stop leak products. I understand that there are opposing thoughts on just tightening the bolts. Maine can you help?
2.) I want to purchase a bimini top. I think it will have to be a short top, aft of the boom. I hope some Cat 36 owners will give me some direction.
STILL TO DO:
1.) Fix pin hole leaks in anchor locker, it is wetting my bed!
2.) Get the engine fan working.
3.) Install solenoid for glow plugs.
4.) Fuse battery.
Happy August All!
Nick
QUESTION:
Nick,
Engines 101 - The BIGGEST & BEST collection of M25 Series Universal Engine Information on the Internet, plus some M35, too :)
http://www.c34.org/wiki/index.php?title=Diesel_Engine
There's a replacement of the oil pan with the engine in the boat in those links.
If you find a Stop Leak that works, email me so I can get rich overnight. :eek:
Get a new dipstick with a seal on the end.
Sep 23, 2009
1,475
Fuse the battery.
Quick, cheap, fast, easy, and important.
Also be glad your list is so short :dance:
Jan 27, 2008
3,086
ODay 35 Beaufort, NC
Re: the cap shroud leak. Leaks like that usually mean wet core in the deck unless Catalina laid up the chain plates area as solid FRP? If the chain plates stay wet they can crevice corrode. Inspect them closely as failure is catastrophic likely a dismasting. Stopping the leak won't dry the core. Best to dig it out and lay up solid fiberglass in those areas.
dhays
Aug 2, 2010
93
Catalina C400 Gig Harbor, WA
Reply to an old post....
Jibes is right. chain plate leaks on the C36 mean a wet core. I had an 84 C36 with that problem. It is a tough fix so first stop the leaks, then see what you want to do with the core. Any soft spots on the deck?
