Here it is, my final picture of the H37C vanity project. And still it is not done. I forgot to shorten the corner trim pieces. And I have yet to install the bungs. But you get the idea. The bottom of the mirror(new) frame actually rubs on the top of the faucets when opening. But not enough to warrant trimming the bottom.The drain was a bit of a problem. The hose accepts 1.25" tubing but the drain is 1.5". I used a PVC adapter, about 3" long, that had compression rings for both sizes. Otherwise no problems.You might be able to tell that the "wallpaper" is painted. It is an offwhite, much brighter and easier to clean.
