My cup runneth over... part II
Would that be the keel or dagger board version...
JamesG161
Feb 14, 2014
7,908
Hunter 430 Waveland, MS
In @Kermit post #35 Singing about being Green, I finally saw what I always kinda expected...
Kermit the frog is a...
"Knuckle Head" :yikes:
Check song at about 1:50 - 1:58 lapsed time for the proof!
Jim...
PS: You can go "off the rail" in this forum:biggrin:
Gene S
Nov 29, 2015
181
Delphia 37 Tacoma
I'm going with G. The liquid will run out the lower ports first. Is this what its going to be like all winter? Cabin fever setting in early this year. My boats in the yard getting some work done so I'm grounded too.
Feb 17, 2006
5,274
@Gene S it can't be G. The pipe from C to D is blocked, like the cooling system on my outboard. :yikes:
Sep 20, 2014
1,330
Rob Legg RL24 Chain O'Lakes
Seeing that the drop has not been adding to A it is likely that those answering "NONE" may be correct.
On the other hand if the spigot and the force of the fluid behind the spigot is greater than the puny outlet (drain hole) in "A" then the answer is of course "A" will fill first just like the oil collection container does when I choose the small one on my boat. And the fluid will overflow "A" with vengeance until the spigot is closed.
Wow and I thought that was going to be hard...
the correct answer is either A or A. If the flow is fast enough, then for the above reason, A is correct. If the speed is slow enough, mold will grown and plug the drain hole, so A will again be the correct answer. You are asking boaters.
jwing
Jun 5, 2014
503
ODay Mariner Guntersville
The only possible path for water is A - B - C - D - G. There will be no water in any other cup. BTW, outlet for C is on back side.
EDIT: Well, I went back to read the other responses and I found that Hayden Watson beat me to it in his reply #7.
