G
Gary B
The centerboard on my OD 25 is stuck up. Anybody experience this before? Is there a right proper cure? How can I get it out?Is the center board supposed to retract fully into the centerboard case? For storage could I set the boat down on its keel with the board safely and fully retracted? I have two suspicians for the cause of this dilemma: The centerboard was partially down when I was lowering it onto the trailer. As the boat settled on the trailer, the centerboard swung up and the cable got jammed between the centerboard and the case. Zebra mussels made a home in the centerboard trunk and jammed the centerboard as it came up.I posted a couple pics of the boat. You can see the partially retracted board. TO Charlie Newman: I intend on removing my center board to resolve this problem. If you want pics of the board, then please let me know.Finally how do I take the centerboard out?
