A
Al Nash
And I'm not alone!My bilge pump sometimes doesn't start against the head of about four feet of water beyond the check valve; it starts pumping 90% of the time; the rest of the time it just spins. So I decided to remove the check valve but then I have the problem that after pumping, the water in the 15 feet of hose drains back into the bilge. The pump starts again and repeats and repeats and ....I've tried two bilge pumps (Rule 2000) and two check valves. I also looked for a switch that had a larger height difference ( need two inches) between on and off to no avail.Upon discussing the problem with others in my marina I found I was not alone!I see no practical way of shortening the hose in my boat (Hunter 34; in fact if I do away with the check valve I plan on adding a vented loop; that will make my problem worse; more hose and more height. The only place for the vented loop is near the discharge.Any suggestions?
