Guess it was a few weeks ago when I asked a ton of anchor roller questions.
Finally managed to get the project completed - here are pics of the finished product.
I used a 24 inch long piece of 3 inch wide by 3/8 thick 2026T6 under the roller assembly. This functions more like a "top backing plate" than anything else.
The roller itself is bolted through this and the deck with a large 1 inch thick oak backing plate. The other end is likewise bolted via the four bolts on the six inch SS cleat I added. The front of the roller is lagged to the bow with a bracket of 1/4 SS.
I can stand on the front of the roller, bounce up and down - and nothing moves. I beveled all holes and used "bedit" butyl. Had a few good rainstorms and no evidence of leaking. I went with a single roller as I always deploy my second anchor manually after the primary is down. It's a danforth that hangs from a pulpit mount - light and easy to manage. Rowing it out in the dingy gives me something to do since I'm out there anyway checking the primary anchor set.
One extra thing I need to do now is add a roller to the trailer, under the front portion of the hull. If I don't, the anchor and roller will hit the trailer post as the boat slides off the trailer.
Now we just need some warm weather so I can get the boat finished and in the water!
Chris
Chris
