My accumulator blew up
C
craig
We had alittle rough go dealing with our fresh water system this spring. Here it is july 1 and we just finished filling our tanks. First off, all kinds of flooding here in minnesota so the boats were very late getting in. I took the cover off the boat. I had a bilge 2/3 full of water. That was very unusual. Got the boat in .Had to wait 3 weeks to get the dock water turned on because of the flooding. All the lines broke when the docks were raised by the flooding. We finally got water. Attempted to fill the tanks and pump the antifreeze out. My wife says to me, hey shav come down here, the water is running all over the floor. Lift up the cushion over the water heater and see a bulged out water heater end and water all over the place. Well, one bracket on the bottom of the heater is rusted off so I go on the internet and order a 6 gallon seaward repl. for 172 no sales tax and a 55 dollar savings over boat us. no shipping over 50. takes ten days to get here. thats ok. We installed the heater on a day when the temps inside the boat were 90+. Everything went as expected. all the fittings were exactly the same and the wiring did not change. Last fall we bought a new pump and i put an accumalator in line. both from shurflo and both worked fine. As we were filling the tanks we put the water pressure switch on so we could empty the antifreeze and BAM, the accumulator blew up. What happened? I bought a piece of water line and took the accumulator out of the system and finished my work. Everything works fine except my blown up accumulator. This two hour job took only six hours. By the way, our heater has back mounted heatexchange hoses. you have to make a choice when you order the replacement. craig
E
Ed Schenck
Tough season so far.
Seems that way here on Erie too. All jobs take too long and very little sailing. Just commissioned my water system two weeks ago. When the winds and waves are right have to let those projects slide I guess. That's a good reminder about tank options, thanks.
A
Arthur Boas
Ice
The accumualtor had some water in it that froze, creating a crack. Same thing happened to me
Peggie Hall/Head Mistress
Sounds like insufficient winterizing
Only one thing I can think of that would account for a bulged water heater, and a cracked accumulator: both were full of water that froze solid. Either you didn't use enough antifreeze or it wasn't rated for the temps you had in MN during the winter.
Tim Schaaf
the good news.....
is that you needn't replace the accumulator tank. The Shurflo pumps work just fine without an accumulator.
Sam Lust
Make your own - better and cheaper
My Jabsco accumulator died of terminal bad quality. It split at the boss where the hose fitting screws in. And yes, I had tightened it moderately. I made my own out of a length of 6" PVC pipe, (a little under 2 feet) two caps and a plastic pipe threaded hose barb fitting. It is stuck in an otherwise unusable dead space in the head's sink vanity and held in place with tie wraps. Mine's capacity seems to be about 4 or 5 quarts. I can run out about 2 quarts before the pump kicks in. I don't like having the pump constantly cycling as I use the sink, and reduced cycling will increase the lifespan of the pump. Total cost? About $10.00. Repeat after me: When It works, cheap is good!
C
craig
I called shurflo
I called them today. Her response was I needed 20 lbs of air pressure in the accumulator. I told her I relieved the pressure last fall as the instructions told me to do but had no air in the tank at the time of impact. Rather than argue about it, we are small users of the water so I will just deal without it as the pump works fine. By the way, I ordered the 6 gallon seaward water heater from sailnet.com and was very impressed with their price savings over boat us. craig
