This works!
Bill, I have found the difinitive answer to this problem. Star Brite silicone marine polish! The stuff drives out all of your dull gel-coat oxidation over time, while replacing it with sacrificial silicone down inside it. This creates a barrier that the UV can eat up instead of your gel-coat. This same barrier stops the soot from entering the gel-coat too. If you use the stuff again and again, it builds up a nice little shine, kind of like brand new! Elbow grease is key, but after a few applications, the soot wipes right off with a little more polish. It seems that the 'moist' portion of the polish acts as a solvent quickly removing soot or scum or whatever. Works great for your gel-coat strip just below the boot stripe too! Each application makes her shine a little more and a bit easier to clean the next time. But at least two applications/year are a must. It contains no abrasives. It is the only product that I use for the exterior gel-coat on Best Revenge, top sides, and cabin top. Not on the non-skid tho'! Too slippery! Ron
