mushroom anchor
2
- - Charleston, SC
I was wondering what size mushroom anchor would be good for my cat 22. It will be in 8 to 16 feet of water in a saltwater creek. Some sources I saw said 150 lbs but I was wondering if I could go with 100 and all chain (2.5 to 1 on scope) and I'd haul out for storms. Thanks
Jun 5, 2004
97
- - Greenwich, CT
100 pounds should be OK
I've used 100 pounds on my mushroom anchor with no problems, however my scope was at least three to one. I think you do not want to go below three to one for the scope unless the anchorage is so crowded you must do so. Use a combination of heavy say 3/8 chain on the bottom and then maybe just 1/4 on top. The 1/4 will need to be replaced every two years or so.
