Some thoughts..
Kellets are often misunderstood and there are a few things to consider before using one. I would not use an anchor, mushroom or any other type, as a kellet though. In light winds the boat could swing to the mushroom but then if a wind or tide shift occurred the rode would 180 back on its self and when the loads got high enough, in the opposite direction, the mushroom can or could be pulled straight at the main anchor and foul it.
Some things to consider:
1) Kellets offer very little value when you need them most, which is in high winds. A 40 foot boat using a 33 lb kellet, as illustrated by Alain Fraysse in his book on anchoring, would draw the rode tight in only 30 knots of wind! Considering a 40 footer would only require a good 44 pound anchor to begin with a 33 pound kellet is HUGE. Most kellets are not 33 pounds..
2) If your anchor is dragging in under 30 knots of wind the kellet is NOT your answer your answer is a bigger, or better, anchor.
3) Kellets can foul your main anchor.
4) In order for a kellet to put max horizontal load to the anchor to keep it dug in it needs to be as close to the anchor as possible. Unfortunately kellets hang off an anchor rode and if you put it close to the anchor it will be doing nothing but sitting on the bottom adding little value.
5) For maximum shock loading the kellet should be placed at the mid point of the scope. This though does not help your anchor stay parallel to the bottom. A compromise is for it to be located 25% of the way from the anchor but then this still does not give you optimum anchor angle and shock loading reduction. Again the additional weight of a kellet would be better served placed into a main anchor, more chain or using more scope.
6) Seeing a most kellets weigh considerably less than 33 lbs, like the one used in Fraysse example of the 40 footer, it is safe to say that a 15 pound kellet, on a 30 some odd footer, will see the rode go straight in considerably less wind than 30 knots. Again, if your primary anchor can not hold your boat in 30 knots that is your issue.
7) Adding more chain as opposed to a kellet, which can be tricky to deploy/retrieve and can in some instances cause unwanted chafe on the main rode, is a better spend of money.
Kellets are good for some things just not helping in keeping your caternary in higher winds.
Kellets can:
*Help dampen and minimize sailing or swinging at anchor
*Minimize swing radius in light conditions
*Help dampen a boat and keep it stationary when bow/stern anchored
*Help ensure that rode is kept down and away from the boat’s keel, rudder, and propeller (but so does chain).
Kellets can't:
Keep a caternary in a rode in high wind conditions when you need them most, unless they are very, very, very heavy, at which point it would be wise to just add a bigger anchor.
In short if your anchor is sized properly, and you use proper techniques, there should be almost no situation where a kellet is necessary. Any anchor/chain combination for a boat should hold that vessel at a 7:1 scope in winds to a MINIMUM of 40 knots. If you are dragging anchor in less than 40 knots please get a new anchor first rather than trying to band-aid an improperly sized anchor into thinking it is bigger or better than it really is! A more comfortable design is an anchor system sized for a at least 60. Remember a kellet in most situations stops working as "intended" at about 30 knots give or take depending upon the weight.
