munter 34 weather helm
15
hunter passage42 lighthouse point fl
put more twist in mainsail pull traveler up to wind and release boom vang should only need 1 reef and an :dance:some fat guys on the weather rail
RichH
Feb 14, 2005
4,773
Go here to evaluate your 'weather helm':
If you are using http://shop.sailboatowners.com/prod.php?51998/Sail Trim Users Guide or equivalent (usage of full set of tell tales, etc.) for trim and sail shape ..... and you still have 'weather helm':
• Sail SHAPE problems that cause weather helm: http://forums.sbo.sailboatowners.com/showthread.php?t=120970 (post #1)
• Rigging tension problems that cause (apparent) weather helm:
http://www.ftp.tognews.com/GoogleFiles/Matching Luff Hollow.pdf
Then, if the above two dont reduce your 'weather helm', then and only then 'rake the mast'.
