A
Anne Castleberg
On the H450 there are two holding tanks and two macerator pumps. Since we purchased our boat two and a half years ago we have had onging problems with the front (bow) pump/tank. Initially we had the original pump fixed numerous times. Then we replaced the original macerator pump with a better model Jabsco thinking the first pump had overheated and burned out. We still continue to experience what can best be described as an intermittent problem. The pump (this new one and the old one after we'd had it repaired) would work for a while, maybe one or two times and then - it failed. Our mechanic called Jabsco about the problem with the new pump and they said the only way the particular problem could occur, a rubber valve getting turned backwards is if we failed to open the through hull. But we are not novices and always open the thu hull. We have not had a problem with macerator pump for the master bedroom head. Any ideas, could there be a problem with the holding tank, or the through hull - our diver has checked and it is clear and unobstructed from the outside? For now, once again we are installing the spare, older model jabsco that we had on hand. But this is getting ridiculous and expensive.Any help appreciated.Anne and Grant Castleberg on Pilgrim in Santa Barbara
