It has always been my understanding that it is best to take the charging leads directly to the positive battery terminal. That was fine when we had one or two charging sources, but with the addition of a windgen, I'll have 5 independent charging sources.
To make things neater and simpler, I am considering having all the charging leads go to a high amp power post or a bus bar of sufficient size, then to the battery with a #2 battery cable.
This would leave me with only two connections on the positive battery post.
Is there any reason why this would not be a good idea?
