Bob E.
I sail on Lake Ontario and I know that a "Y" valve between the head and the holding tank that would permit direct overboard discharge from the head is illegal and subject to an up to $5000 fine if caught in one of the random CCG inspections. My 1989 Hunter 30G does not have a Y-valve, but it does have a manual diaphram pump (located in a closet in the head) and thru hull that would allow the holding tank to be pumped overboard. This is in addition to the deck plate for marina pump out. I guess there is little difference between raw sewage from the head and "seasoned" stuff from the holding tank, and maybe it's splitting hairs, but does anyone know if this arrangement is just as illegal? I would never use this thing on the Lake. Would just wiring the seacock closed satisfy the CCG requirements?If I've got to disconnect this, I'm considering converting the large manual diaphram pump and 2" hose to an emergency backup manual bilge pump. Has anyone done this?Thanks.
