Think before you leap
You can get all the supplies you need and it probably isn't all that hard. However, consider the effect on the way the boat sails. If you move the traveler forward, you are increasing the amount of "pull" required because you are decreasing mechanical advantage. Sure, it's convenient to have the damn traveler out of the way, but it probably isn't efficient. Why not work your bimini (which is, after all, only a convenience) around your traveler (which is, after all, a working part of the boat)?
