Mike
Greetings,I had a Johnson 9.9 on my O'day 25. It finally gave up the ghost. Bought a 8hp fourstroke. Took off old motor and bracket (told not beafy enough for four). Bought new Garelick bracket. Old holes lined right up! Too good to be true? Yes. Mounted new motor (20 inch shaft Tohatsu). Drop engine and end up with cavetation plate just in the water! This bracket has a plastic block that the motor hangs on. IT has lots of holes in the back but only four in the front. I still have the wood block form the old one. Its curved (age) and starting to delaminate. I could cut a new wooden block with the top closer tot he top of the bracket or try and drill neew holes in the plastic. Either way this will only get me an extra 1.2 to 2 inches as that's the point at which the locking nuts on the motor would hit the top of the pracket. Though I could make the wooden block wider and allow the arm on the motor to shift left or right so one is in the middle of the bracket and the other just off to one side. Dropping the bracket would only get me 2 inches or so as its close to the bottom of the transom now. Very expensive bracket. But don't want to lose very expensive motor either. Ideas. I don't use the engine much as I'm on a mooring but . . . What is the optimum depth for the motor. Even with the old one, if I went to the bow to drop the headsail the prop would come out on any wave!Mike
