Mike
Greetings. Finally dropped the mast, mounted the new organizing plate under the mast step, mounted the deck organizer and rope clutch after sailing them around in the cabin for a couple of years. NOW COMES THE BIMINI. The thing came with self tapping screws. I've checked around the docks and found several with the self tapping screws. I had bought some 2 inch stainless screws and lock nuts. The port quarterbirth has a lower wall (ceiling) with access ports which aren't of course located where I'd like to mount the bimini anchors. What about using the self tapping? I just see cracking gelcoat a coming. The boat is a '76 so its been around a while. Second question. Bought all the hardware except the plate below the mast step from Ruddy. The shackles attached to the blocks don't fit through the hole in the plate (as I found last night as the last step to running the lines aft). Can I grip these with the vise grips and run it against the file to knock it down enough to run through? No grinder and I'd like to do it at the boat if possible.Thanks,Mike
