DEALER INSTALLED BINNACLE GUARD
None of the "older" H31's came with a binnacle guard installed at the factory, but it was (is) an easy do-it-yourself project. I had mine done by the dealer when I purchased the boat in 1986 (mine's a 85 model), but I watched them do it and it was a cinch. While there are several types out there, you want to make sure the one you get does what you got it for: protection for the steering quadrant, a mounting point for a cockpit table/GPS/drink holder, and most importantly a SECURE grab bar to assist in moving around the cockpit. As such, mine is mounted to both the binnacle (sort of a "Y" attachment under the compass housing with the tops of the "Y" securing the guard) and attached to the deck by a "cup holder" which is screwed into the deck w/ plenty of sealant. I've never had any leakage problems and since the screws don't penetrate the cockpit deck core, doesn't show at all in the aft cabin. Take a look at the various manufactures models and I'm sure you will find one which will work for you.Tim (TIDE)
