mounting jib whisker pole to the mast
Sep 30, 2019
15
Hunter SD SD 41 St.Simons Island, GA
I would like to install whisker pole track or ring to the sail in the mast. 2008 41 SD.
Is there problem on wires or tapping screw for T track ?
Dec 14, 2003
1,423
To avoid the sharp pointed end of self-tapping screws, I used short machine screws after drilling mast carefully and tapping. No problem with wires or halyards.
Likes: jngotasail
Apr 5, 2009
3,079
I agree with Claude, use short machine screws and tap the threads in the mast. I found a few of my screws had a small burr on the ends which I cleaned up with a Dremel before installing.
I would suggest not using a ring for the mast mount. That is what I did and it is the one part of the system that does not work well. With a ring, the pole will bind up if it is not facing in the right direction so I always need to rotate the pole before deploying the pole and it is a pain. I plan to change out the ring for one of these. heavy duty car
For the up / down control line I used a couple of Spinlock PXR cam cleats for the stoppers on a continuous line. The line has only enough slack to allow the center between the cleats to come out about 9" from the mast. They are about 5' apart with the upper one at the top of my comfortable reach and the bottom one at the bottom of my standing reach so I can make a full vertical pull. To adjust, I pull the line at the mid-point between the cleats like drawing a bow which releases both cleats and adjust as needed. I lock both of them at once by pulling the mid-point of the line around the front of the mast. Works great and I love having the pole vertically mounted.
I can do a dip-pole jibe with the genoa by raising the car with the pole still extended which brings the end into the side of the boat so I can swap out the sheets. Then I lower the car until the end of the pole is just inboard of the forestay so that I can swing it across to the other side. I marked by control line to make that easy. Then to jibe, I just release the old sheet and trim in on the new one and the pole pulls the sail across then rotates back. Very slick.
Likes: Valerio
Dec 25, 2000
5,904
Before you go too far with your project, it would help to know what kind of mast you have. Do you have the brand, or a photo would help? Our Isomat mast (different model) has an integrated track mast extrusion for a car that can be used for most any kind of pole. This would eliminate the need for a separate mounted track and assembly.
This is the car in question. Isomat Spinnaker Cars
This is the Isomat spar in question: Isomat NG Mast Specifications & Components
Feb 10, 2017
305
Hunter 41 Progreso
HI is a Selden in mast roller furling, the only hyliard i have is the one for the spy, i would like to install an additional one have you done that too ?
Dec 25, 2000
5,904
It appears the Selden spar does not have the extruded spar track like the Isomat spar. Yes, I did install a separate asym halyard on our boat.
