mrbill
Hello,I am about to mount a perko adjustable hatch support on my 88 26D.I'm looking for advice from those who have installed them, or have it installed. FYI, the top of the support is gimbaled, to mount under the hatch. the base has only a vertical swivel capability, it can only move in a plane, not multi direction.Note: a wedge is required to mount the base in a 90 vertical plane. (which I have made).I was going to mount the base rearward, so I could tru bolt the base to the FG opening. However the opening of the hatch requires this mount to also move outward, (Not in a vertical only plane)so, I have moved the base forward, (as some recommend), which fixes the rotation.... However I cannot thru bolt the base, only screw into the fg hatch. (and wedge).to those that have this already installed.... will a screw installation hold up?how did others install their bow hatch supports?thanks. bill in ftl.
