Now that I have my new Garmin Echo Map 50s Chartplotter, I need to mount it. I haven't found anything useful "yet". My 20 year old hand held had a plastic clamp accessory that fastened around the grab rail hoop in front of the binnacle. The old unit snapped on and off with ease - clean and simple.
My new GPS is larger and heavier, and the mounting that came with it is designed for screwing into a flat surface. I don't have a flat surface to work with, so unless there's some hardware out there that I haven't yet discovered, I'm going to have to create something.
I spent the better part of an hour behind the wheel last night letting my mind try to solve the problem. There were two ideas I came up with.
One idea I didn't like much, and that was to build a 4" platform of wood up from the teak table in front of the grab rail.
The other was to take some scrap teak I have (3/4" thick) cut it to two thicknesses of about 3" wide by the width of the two sides of the grab hoop. Notch each side so that I could straddle the railing on both sides like a two pronged fork, and then secure each side with screws through the tubing into the wood, and maybe underneath use something like hose clamps to help with stability.
Anyhow, if there's an easier way to do it, I'd sure appreciate your thoughts and any photos you have.
