I'm installing an Aries windvane on my transom. I'm concerned about all the weight on the stern (outboard, propane, vane and solar panel) so I'd like to keep the wind vane as close to the transom as possible.
That means the solar panel will be right over the aft deck. It's a small boat so there's not much room back there. I'd like to get it at least 24" above the top of the rail.
I'm pondering mounting options:
1) Bimini hardware to mount it off the rail (expensive but doable)
2) 2 Lifeline stanchions on the deck with long tubes to support the panel. (really long tubes and ? of the leverage that the panel might put on them).
Any thoughts?
Thanks
Any thoughts?
Thanks
