Mounting a Radar on the mast
David Dick
I am mounting a radar on the mast of a 2001 - 340 with in-mast furling. Can anyone tell me the best height to mount it, or any other tips that might help the job go smoother. Thanks.
Steve
How about on the arch?
Why are you using the mast? The top-rear of the arch keeps it out of the way, and no sails will hit on it. You might gain a little range by putting it higher on the mast, but with a sailboat why would you need that?
Jim
Reconsider
If your decision is still in the flexable phase---then think about an Edson Post mounted on the stern. A better pictuer. Less problems.
Daniel Jonas
Radar
David, To answer the question. Somewhere just above the first set of spreaders should work. We have ours mounted there on a 290, works fine. I like that the transmitter is away from where I stand. No problems that we can tell operationally. Works well and we like it. We do not have in mast firling, so just make sure that the mount does not cause a problem. We suspect it will not as it mounts pretty much on the front of the mast and uses rivets. Dan Jonas (S/V Feije)
Mike D
Some considerations
Dick, We have in mast furling and mounted our unit under the first spreaders. The routing of the wiring will be more difficult than using an Edson Pole aft. Since the radome outputs at a fixed angle, you will have a blindspot around the unit. The higher the unit the larger the blindspot. Since, in fog you will want to see vessels before they are very close, this is usually not a problem, It is worth checking out ahead of time, however. If you desire to use the unit sailing, I would recommend a gimbled mount. They are very expensive. They do allow your radar system to "see" level when your boat is healed over. With a fixed mount, your windward side radar view is " in the clouds" and your leeward side is shooting the water immediately aside your boat. We chose the mast mount to keep us out of the radiated emissions. Although the emissions are said to be non problematic, we are more comfortable with the mast mount. West Marine 2001 catalog page 123 under Waltz Radar Leveling System states "typically 12-18" below the first spreader". Study it on your rig, since it can interfere with tacking at times. By the way, we were talked into the 4kw unit by our marina owner. He quoted it would see crab pot floats. We were told that this was crazy by tug boat captains. But, IT DOES WORK! If the seas are pretty calm, we advance the gain and "light 'em up for night time sailing". I am sure this will cause alot of doubting Thomas's curiousity to sprout, however it is the truth! good luck, Mike D
