Motorcycle Gear for Sailing?
Tedd
Jul 25, 2013
793
TES 246 Versus Bowser, BC
Yesterday, I sailed for the first time ever in cool weather--about 10 C (50 F). I had a decent clothing set up but I expect to sail in colder weather soon. I got wondering if anyone here might have tried motorcycling gear while sailing. I have a Scott two-piece riding suit with only a few thousand km on it that I plan to wear next time on the boat.
Feb 21, 2013
4,638
Hunter 46 Point Richmond, CA
No, too restrictive.......why not consider a diving dry suit?............used that wind surfing in the winter. For cold weather sailing, I sail with thermal synethic layers and cold weather outer gear, including foulies, neck warmer, gloves, fleese hat and wool socks. Good article on what to wear in cold weather: What To Wear When Sailing - Better Sailing.
4,338
wool
what kind of bikes yawl ride.
me, bmw 1150 r 2004
ski suit, snowmobile suit, bibs & parka, i'm a mitten guy, layers, gortex, goggles
260
Catalina 30 Lake Perry, KS
I use a heated motorcycle jacket ( Gerbing) which is very lightweight and use my foul weather jacket over it. It is plugged into a 12 volt cigarette lighter. Works great on the boat and bike. Never got cold , even at 20 F. Out of bikes due to balance issues but sure do miss it. You can get heated gloves (too big for sailing) , pants and socks.
Bultaco 250 Pursang Race bike, Various Triumphs, Bridgestone factory 90 race bike many more over the last 60 years. Last one was a BMW R1250. Yes I am an old fart !
Tedd
Jul 25, 2013
793
Thanks, @Sanfelice . Nice to see another Triumph rider here. I have a '95 Speed Triple. I haven't ridden it in a few years though and will probably sell it next summer.
Heated gear hadn't even occurred to me. I don't have a cigar lighter in the cockpit but it wouldn't be hard to add one.
Likes: Tin Kicker
Feb 21, 2013
4,638
Another option is to install heater vents in the cockpit that blow hot air from a diesel heater. Had that on my skiboat with hot air from a heat exhanger on the engine water circuit for winter skiing.
360
MacGregor 26S, Goman Express 30 Kerr Reservoir
I ride with a Firstgear Thermo One-Piece Suit on cooler mornings coming into work. The concern with using it on my sailboat is that at times, I am quite active. This suit is designed to keep the wind off of me while I am sitting mostly still on the bike. It doesn't take much physical activity before I become too warm. Once this happens and I start to perspire, then I get cold rather quickly afterwards and can't get warm again.
JamesG161
Feb 14, 2014
7,935
Hunter 430 Waveland, MS
Ask my friend @jssailem , who I nicknamed Mr Mummy, about his Foul Weather gear.
Warmer in the South
Captain Jim...
Tedd
Jul 25, 2013
793
I can see that happening with a one-piece suit. I think it would not be as much of an issue with my two-piece suit because it's so easy to don or remove the jacket. It seems like a two-piece motorcycling suit is pretty similar to sailing cold weather gear, except for the armor.
1,923
All you could do is try it. I would expect it to be to restrictive on my boat with how it is set up and not covering the right places enough. I excessively large collar with a adjustable hood are items on a good fouly that won’t be on riding gear.
Tedd
Jul 25, 2013
793
Good point, @MikeHoncho . My riding jacket has no hood and only a modest collar.
I guess a good fouly hood has a string so it can be pulled in tight around the face? I hate having my peripheral vision blocked.
A good fleece or wool beanie can serve to keep the heat in on your noggin.
I like the wool over my ears do reduce the chance of frostbite.
Check out my avatar... Sailing the Gulf Islands BC.
