Needs a Bleed?
Usually the only thing (outside of a MAJOR mechanical problem) that will cause a diesel not to start is either bad fuel or air in the fuel lines....1. If you just bought some new fuel and the problem "magically" appeared, I'd start there..the "solution" is to pump all of the fuel out of the tank and buy new....how and with what you do this I have no idea and hope I never have to! <g>2. If you haven't recently purchase fuel, I'd try to bleed the fuel lines (make sure to open the muffler valve prior to doing so to keep seawater out of your engine!...Also, make sure your fuel valve is turned on, if it isn't, that MIGHT be the problem! <g>). If its an M-25 (that's what I've got) you need to turn on the fuel pump (turn on the key), then first loosen the bleed nut on top of the secondary fuel filter (the one on the engine) until air-free fuel pumps out (catch any spills -- DIESEL STINKS!), then loosen the "knurled knob" on the injector pump, the fuel pump speed should increase and the slow down (but mine never does!), then try to start...if it still doesn't start (as mine never does), then loosen each injector (at the cylinder) one at a time starting with the one nearest the injector pump until air free fuel flow from each (this is what I have to do to get a start but I've been told by others that it SHOULD be unecessary)3. If the bleed procedure doesn't work, you may be looking at some sort of compression loss that will almost always be costly to repair....but....check that the air intake isn't clogged?That's all I can think of...Steve Treppa
