Motor size
2
Hunter 18.5 WV
I have a Hunter 18.5 with a Johnson 3 HP 2 cycle no reverse. I own a Suzuki 9.9 HP 4 cycle. The Suzuki weighs 120 lbs. Is this engine to heavy and have to much torque for the Hunter?
Raftco
Sep 23, 2009
59
Catalina 30 MKII, Fin Keel Harwich Port, MA
I would stick with the 3hp, 2 cycle or something of similar nature.
A 9.9 4 stroke is a heavy engine, and in fact they are too heavy for my O'Day 25 without upgrading the transom and engine mount. I would venture to guess that it would be overkill on your boat, but you can always to a dry test to see if it will actually fit.
BrianW
Jan 7, 2005
843
Hunter 26 Guntersville Lake, (AL)
Jim, will your 3HP outboard tiller spin around 180 degrees? On some small outboards, THAT is your reverse. BrianW
