Robin
I am a very new Hunter 26 owner, I have a 95 model,it has an 8 horse nissan attached, I am going to put that 8 horse on my dingy, and put a new motor on the boat, I hope to directly mount it on the wooden transom block, we do extended (2month) cruises, so I'm thinking a 15 horse honda, to provide ample power, and a strong 12 amp charge for the house batteries. My initial guess is that a short shaft would work nicely..but will it properly swing up and clear all obstacles in the sailing position? is 15 horse overkill (the 15 horse weighs only 6lbs more than the 9.9)..I know the boat can be bought to hull speed with an 8, but I like the quietness of a larger motor at lower throttle. I would like to hear from you if you are very happy with the motor installation on your boat..Thanks very much...Robin
