Motor opinion
Jul 18, 2020
16
O’fay 222 Bluffton
We just got an O’Day 222. We need a motor and are considering an electric, trolling or small outboard (under 5 hp doesn’t have to be registered in our state). All we think we need it for is to get in and out of marina. We would like your opinion. We would be mostly sailing in and around the Hilton Head, SC area. Thanks in advance. Don
Jul 7, 2004
8,542
Hunter 30T Cheney, KS
5hp would work fine for you. My Mac 26S had one when we bought it. An electric is clean but you may need more battery power onboard. Propane is another option. I've seen them but have no idea how good they are.
Likes: Don Tatarelli
Johnb
Hunter 37-cutter Richmond CA
Just my opinion, but if you spend $1,000 or more on propulsion and don’t get something that could take you 20 miles or more that is too limiting. And while you are at it get the longest shaft you can.
Nov 9, 2012
2,500
Oday 192 Lake Nockamixon
Why not get the Tohatsu propane motor. I think it's 5 or 6 hp, and with a couple canisters, you'd have more power and better range than a Torqeedo. I believe the propane is already a sailpro model with long shaft and high thrust prop.
Jul 18, 2020
16
O’fay 222 Bluffton
Thank you all for your ideas. We settled on a 3.5 HP gas motor available from Amazon and is returnable in case it doesn’t work for us.
Likes: Whatfiero1
Jun 27, 2020
1
Hunter 23 South Cove - Lake Champlain VT
Don, Have you had a chance to install and use the motor? What are your initial impressions?
Jul 18, 2020
16
O’fay 222 Bluffton
Sorry no, because they don’t offer a long shaft it wouldn’t work for us. We are looking at used motors now. Thank you.
Sep 22, 2018
1,869
Hunter 216 Kingston
You might want to consider the “sail pro” models from Tohatsu as they offer an extra long shaft version and a standard alternator.
I appreciate you are trying to stay under 5hp and I think 6hp is the smallest sail pro but maybe you don’t need extra long shaft anyway.
You also mention you think you will only use it to get in and out of your harbour but I would point out that weather is predictably - unpredictable :) If you need to motor to safety it’s not a bad idea to have lots of power on hand.
A number of posters here have expressed their positive satisfaction with Tohatsu product.
16
O’fay 222 Bluffton
thank you. We will check out that model. The five hp isn’t a huge deal. It just doesn’t have to be registered in SC if it 5 or under. Just one less hassle but not really a big one.
Likes: Hunter216
Sep 22, 2018
1,869
Hunter 216 Kingston
Your welcome.
They make 5hp and under models as well that are both short and long shaft, just not extra long (not positive about the extra long thing). :)
1,753
the tohatsu 5hp propane comes in three models;short shaft, long shaft, and extra long sailpro. The extra long sailpro has an alternator built in, all have hi thrust props. smooth,easy starting, great engines.
Jul 18, 2020
16
O’fay 222 Bluffton
Actually we changed our (OUR?) minds. We found out the original owner of the 222 still has the motor he had on the boat. Sounds like a good one with not many hours so he is making that available for a great price. Won’t get it for a few weeks though. Thank you. Don
Jul 27, 2011
5,197
Bavaria 38E Alamitos Bay
Could be a mixed bag. I assume it’s a fairly “well-dated” engine if first purchased with the 222 model, the last of which was built in 1988. Two or four stroke? Anyway, outboards that are not regularly run develop “chronic reliability problems“ in my observation. Low price going in, but then a few hundred $$ getting it serviced, etc. I presently have four of those little PIA so I’m an expert on the subject. John Steinbeck apparently was also. FromThe Log from the Sea of Cortez—“It completely refused to run: (a) when the waves were high, (b) when the wind blew, (c) at night, early morning, and evening, (d) in rain, dew or fog, (e) when the distance to be covered was more than two hundred yards. But on warm, sunny days when the weather was calm and the white beach close by—in a word, on days when it would have been a pleasure to row—the [thing] started at a touch and would not stop.” :doh: A 5-hp is probably sufficient for what you wish it to do. Welcome to boating! Enjoy!
216
Seaward 25 777 Fort St. James
Could be a mixed bag. I assume it’s a fairly “well-dated” engine if first purchased with the 222 model, the last of which was built in 1988. Two or four stroke? Anyway, outboards that are not regularly run develop “reliability problems“ in my observation. Low price going in, but then a few hundred $$ getting it serviced, etc. I presently have four of those little PIA, so I’m an expert on the subject. A 5-hp probably sufficient for what you wish it to do.
That sounds like a "First World Problems" assessment. Those old engines last forever with regular maintenance, and tuning them is child's play. No need to spend hundreds even if they need a complete rebuild. But the OP didn't say this was a motor that was originally on the boat, just the most recent one on it. My 1974 boat came with a 2006 Mercury, but I swapped it for my reliable 1980 Johnson because I could not stand the silly throttle--combined-with-gearshift on the Mercury.
Jul 27, 2011
5,197
You may have misconstrued, but first I wonder how long since your Jonhson has been in the shop? Maybe it never has and if not, good for you. But do you use it in seawater as with the outboard use we’re discussing here? You may not have had the pleasure ($). I did not mean to suggest that “vintage models” are any more inherently problematic than new models, only that a prolonged lack of regular use can lead to problems. The OP mentioned “not many hours” as a selling point. I wonder how one could know that w/o a meter or useage log. Does it have one?
216
You may have misconstrued, but first I wonder how long since your Jonhson has been in the shop? Maybe it never has and if not, good for you. But do you use it in seawater? You may not have had the pleasure ($). I did not mean to suggest that “vintage models” are any more inherently problematic than new models, only that a prolonged lack of regular use can lead to problems.
I was lucky enough to have had to buy old beater cars when I was a teenager. I am my own shop. The primary problem with the new stuff is that it is made to be so complex to service that throwing it away soon becomes the best policy. The older motors can be serviced/rebuilt by anyone with rudimentary tools and skills.
Sailboat outboards suffer from underuse, not overuse. They don't wear out, they just clog up, from running cold and poor fuel. Taking apart and cleaning is almost always all that is needed, plus setting up slow running and mixture from the original easy-to-follow 30 page owner's manual.
Jul 27, 2011
5,197
So we agree that if a newer (4-stroke) model must go to the shop b/c it’s behaving badly, it might cost a few bucks to get it out?
