motor mounts on 331
1
Beneteau 331 Bayfield
This is my first yr with my 331 2004 beneteau . I was wondering if anyone else has problems in the lower rpms on the yanmar engine on the 331. Everytime I am leaving or coming into port my boats shakes enough to pop out my dentures if I had them . The motor runs smooth otherwise, I am told that it is caused by soft motor mounts and if so have you replaced them with harder ones ? Also another question I have is where have you installed your fire extinguishers ? Thank You Rob
Jun 16, 2005
476
- - long beach, CA
Rob, it may be that your idle speed
is simply set too low. I had that problem on my '94 OC400 with a Perkins engine. It would make alarming noises when shifted in/out forward/reverse, and I even had a mechanic tell me I needed a xmission rebuild, but one day I noted that when it shook, the idle was down around 750. I broke the seal on the adjusting screw, brought it up to 950, and everything was good after that. Smooth running, good, positive shifting, no more problems. Check your idle speed and adjust if needed.
Mike B
Apr 15, 2007
1,013
Beneteau 43 Baltimore, MD
Idle speed
I'll second Larry's comments on idle speed. Had to adjust the RPMs on my 361 with a Westerbeke for the same reason.
Mac
Jun 7, 2006
436
MacGregor 25 KEUKA lake NY
Vibrations..
Rob, I have a Westerbeke in my 2004 B331, it doesn't like the low rpm at all. My mechanic warned me of the soft motor mounts and the need to keep the rpm around 1100 rpm. When I first got it last year I had harmonic issues as well, which I we believe was air getting behind the shaft seal when she was pulled for inspection. The mechanic stated the soft mounts are fine but to keep the rpm up. Without the soft mounts and if it hit a low rpm, it would really shake you up. On the fire extinguishers, never found a good spot either, I keep one in each locker as well as in the lazerette. Better aesthetics being hidden but they are quickly available. Mac
Jun 16, 2005
476
- - long beach, CA
I second, or third or fourth, the fire
extinguisher issue. You'd think a builder like Beneteau, BUILDING BOATS IN THE USA, would be aware of USCG rules and regs, and have a dedicated place for the required number of devices. BUUUUT NOOOOO!! Makes me wonder.
