I have a 77 C-22 I bought about 6 weeks ago.  The PO also sold his 7.5 HP Honda 4 stroker.  This weights 78lbs. The outboard mount that came with the boat seems to be a Fulton Aluminum job.  It was never installed right for the weight of this motor.  It rides way too low(its a long Shaft) and inside the transom it only has SAE washers, not fender washters and nuts.  I also found that this type of mount isn't for this heavy or high of torque outboard.    Does anyone else have this same mount and motor?  What are you using?  I think I could get away with a fixed mount.  With a long shaft I think it would tilt enough to get out of the water.  However, every fixed mount I have found so far, the max weight is 75# and I'm not sure what the demensions are for clearance.  The Honda is 22.5 in from the top of the clamp to the cavitation plate.  Any thoughts?
