Motor Mount
37
Hunter h26 Orange
Ok, Im a tight-wad! I need to purchase a new motor for a 23.5 Hunter. I would like to purchase an 8hp shortshaft so I may use it on a johnboat also! Has anyone ever installed one of the drop down kicker motor mounts on a hunter 23.5? Do you think this may work or would it put the engine too far back? Thanks
Nov 6, 2006
10,164
I used a shortshaft engine on a similar boat and it was not fun ! Ya had to position the crew in the stern corner where the motor was to keep the prop in the water.. It would be much better to put a raised mount (if necessary) on the Johnboat to accomodate the longer shaft.. Only if you sail in a place where there are NO waves will you be happy with the short shaft on the sailboat.
DJN51
Oct 26, 2009
377
Hunter 23.5 East Chicago In
Wouldn't recommend it.I have at 23.5 and in following seas my Yamaha long shaft even comes out of water.Anyway to raise stern mount on jon boat?
Jul 31, 2009
165
None None None
I try to make things easier to do on my boat rather then more difficult. Back strain isn't one of my favorite things.
Jun 28, 2009
312
hunter 23 Lake Hefner
I have a short shaft... and HATE it. Next $$$ I get is going for something else (not boat related) :doh:. But the next $$$ might get me a long shaft. :Liar:
DJN51
Oct 26, 2009
377
If your short shaft works well,most can be extended to long shaft.Had a Evenrude extended .Worked great for years until I upgraded to aYamaha 4 stroke6 hp.Added Dual thrust prop to motor what a difference ,can idle out of slip.
Jun 2, 2004
3,612
Extend the 15" Shaft to a 20" One
I extended my Mercury from a 20" to a 25". Look for Bay Manufacturing in Milan Ohio, See if they have a kit, If you can change an impellor you can do this yourself.
