G
Greg
Last weekend my engine started kinda "rapping" (not the music kind thank god) more of a vibration thing that would lessen at higher rpm's, after getting to port i checked out the mounts and one of the bolts was a little loose, I went through and tightened the hell out of all of 'em, the rapping is still there especially around 700 rpms. The mounts are just blocks of wood, should there be some rubber in there somewhere? It looks like there coulda been a thin strip under the blocks but it could just be some sort of silicone or adhesive. Part two...if I get some 1/4 inch flat rubber and put it in between the engine mount and the block of wood, would that 1/4 inch mess up my alignment too much? or does someone have a better solution.thanks,Greg
