Motor mount lag bolts
RAD88
Dec 15, 2008
163
Hunter 30 Glen Cove, NY
So here's the deal _ I'm having the motor mounts replaced and was asked which lag bolt I wanted to be used. The choices are stainless, galvanized or bronze. I have my own thoughts on this but would like to hear comments first. Thanks
Sep 15, 2009
6,243
S2 9.2a Fairhope Al
stainless steel is a very good choice with flat washers and lock spring washers one of each on each bolt and the proper size drilled hole
Jan 4, 2006
7,227
And in addition to exactly the above, use a sealant under the flat washers to avoid the remote chance of having a long, undetected water leak getting into the wood around the threads and rotting the wood.
Sep 15, 2009
6,243
S2 9.2a Fairhope Al
exactly right Ralph...
oh and its ok to screw them in with an impact but when you get close to bottoming out about the time the lock washer is compressing use and open end wrench to finish tightening as to not strip out the lag screws
Nov 7, 2012
678
1978 Catalina 30 Wilbur-by-the-Sea
I used the stainless with washers and locknuts. Drilled pilot holes and filled the with resin to protect the wood before before bolting the mounts down.
Jan 6, 2010
1,520
Rad,
I have a question pal.
Are you replacing the motor mounts with an exact replacement? Will the mounting holes match? What is the condition of the old holes? Are the threads intact? Is the hole dry with no evidence of water intrusion?
If unsure or if using different mount replacements & the hole spacing is different, make sure you have enough wood between the existing holes & the new holes. Say you have to drill new holes, if a 5/16" pilot hole needs to be drilled, hopefully you will have 5/16" wood between the edges of the holes. There is a rule of thumb that the minimum space can be half that @ 5/32" but because of torque forces pulling up on one side & pushing down on the other side, hopefully, you won't have to go that small.
Also, the exist. holes need be dry wood if reusing them. If not, this would need to be repaired first. Just make sure of the conditions first.
And yes, I would use S.S. lags. The guys nailed it here about caulking, flat & lockwashers.
CR
