Motor mount for H23
Roberto Bisonni
I have a 4 stroke new Honda engine. The motor mount bends when I am going full stroke. However, going slowly works great. It is dangerous? Do I have to change the mount? Which you all advise? Thank you. RB
R. Wheeler
Motor Mount
I replace my motor mount when I put on a 6 hp Merc. The fiberglass appeared to have cracked and I did not want to lose the motor. I fabricated a motor mount from 3/8" aluminum and extended it farther from the back of the boat, this allowed me to have room to drop the tller/throttle down and still be able to turn without hitting the stern. I have had no trouble, was an easy fix.
mikeepp
what size?
How many horses are we talkin? My 5 horse Honda is no problem although my bracket has some surface cracks and I've wondered about the flexing. I would think that this bracket has some steel inside it. Does anybody know about this? What about bolting rods across the top of the verticals on the bracket?
K
Kenneth Pfaff
What Type
If you moter mount is the same U shaped fiberglass one that my 23.5 had then the bending will only get worse. I had a 9.9 Honda 4 stroke on mine and it was bending so badly that my forward thrust was horrible. All the thrust was attempting to raise the stern and drive the bow down. I was also afraid of losing the engine. As soon as I notice it I heading back to port and put the engine in the cockpit. I replace it with a standard bolt on engine bracket, which works fine. The hard part was getting the old bracket off.
Jay Winter
Motor mount repaired
I have a Honda 5 hp on the same style of mount everyone is talking about. I have a wire/cable that attaches to the engine, though it would not be fun to have the mount and motero fall off. The motor mount was cracked when I purchased the boat. I had the gel coat repaired last fall. It looks real nice and I hope it lasts. I will let the HOW site know how it holds up. Jay s/v Winter Solace
Roberto Bisonni
R. Wheler
Can you tell me more about the fix with the 3/8" aluminun? I would appreciate it. RB.
R. Wheeler
Roberto Bisonni
Send me your E-mail address, I hope to be down at my boat this weekend. I will take a picture and e-mail it to you. Much easier to see than to explain. rwheel@ix.netcom.com
