Motor and Rudder Interference
joe perri
Question on connecting motor to tiller/rudder: Is there a piece of hardware that will connect the motor to my tiller in order to prevent the propellor colliding with the rudder? At a critical angle, the motor's prop hits and damages the rudder.
Don
Rudder vs Prop
You could try steering with both tillers(motor and rudder) simultaneously to prevent the rudder from hitting the prop. If you are looking for a device that will connect the rudder to the tiller, West Marine sells a device called EZ Steer. They have a model for sailboats(EZ-70001). Check out the related link.
A
Aldo
Motor Steering Damper Screw
Joe: I don't know if you are having the problem that I am going to describe or not, but we sailed with a sailor one time that had years of experience, that wasn't aware of it, and I just wanted to make sure that this wasn't your problem. There is almost certainly a screw on your motor that will prevent the motor from freely rotating, side-to-side. It is usually under the power head, and has a spring on it. It can be adjusted a little at a time, so that it takes just the amount of force that you want to rotate the motor using it's tiller. This way you can keep the motor centered for motoring the boat straight, but if you need to make the boat turn very sharply, like possibly in a docking situation, you can still rotate the motor. The propeller can still contact the rudder, but it is not something that usually happens accidentally. As I said, I'm not sure if this is the problem that you are describing, but maybe it will help you or someone else. Aldo
C
Campy
Tiller
I think your motor mount may be too far inboard. I have no problem with the full extention of my tiller left to right with out comming near my motor mount, (which I installed after a refit). I might have a bit of cross walking when motoring but I've never had my tiller/rudder touching the motor. Campy
