More Yamaha 25 prop shaft Questions
Jan 4, 2008
149
Yamaha Y25 mkII Long Beach, Ca.
Does anyone know the O.D. of the cutlass bearing? while the shaft is 22mm ( 7/8) the O.D. of off the shelf 7/8 cutlass bearing is a much larger diameter. I have no problem turning down the OD. I need the strut I.D. before tearing out the old cutlass.
Any help from the Y25 crows feel
free to chime in!
cheers.
Jan 4, 2008
149
Nope, haven't had the opportunity. It will be the #1 project next time I haul out for bottom paint.
Best wishes to all through the holidays .
Boffin
Aug 30, 2010
81
yahama 25 Hong Kong
The OD of the cutlass bearing is 11/4 while the shaft is 7/8 . my boat was 25 mark 1 built in 1977.The length of the strut is 4 inches but most of the available cutlass bearing is 31/2. it works on.
