C
Chuck
PeggieI have a Cat 36. I think it may need more vented loops in the discharge lines. I'd like your opinion. Currently, the line runs directly from the toilet bowl to the holding tank. Then a line runs directly from the tank to a Y-valve (possibly a T, I can't remember). There a line goes to a thru-hull and another to a deck pump-out. No where is there a vented loop. I think there should be one between the toilet bowl and the tank, and another between the thru-hull and the tank. Is this right?Thanks
