I'm a not very experienced mid hole sailor from the Canadian prairies and some of the topping lift questions are confusing me.
The only use for a topping lift I can see os to keep the boom up when the sail is down. I have a line from the top of the mast down to a jam cleat mounted on the face of the boom end cap and then thru a Fairland on the bottom of the boom about six inches from the back end just to keep the line from flailing about. The bit of line hanging down from the fairlead is just ticked in. Works like a charm and is easy to adjust. I guess the only drawback is that you can only raise the boom as high as you can reach but can't see why you would need to go higher.
Am I missing something? I also have a quick release shackle at the bottom of the main sheet
Block and just swing the whole boom to one side and clip the quick release to a stanchion when at anchor with the main down. Comments appreciated.
