Last week I posted a "cry for help" related to the discovery after soda blasting our C-34, that the gelcoat had been removed by a PO. Thanks to your responses, I was re-assured that it wasn't a problem. My new problem now is "what to use to remove the stains on our deck and coach roof, that are a result of 'overspray' of the bicarbonate of soda that resulted from the process". I was advised by the contractor prior to the application that removal of these "inevitable" stains is typically done by a simple washdown of the decks with soap and water. Due to problems with his equipment, the cleaning took place over a two day period, and I began cleaning on the morning of the third day. Bottom line... the soap & water didn't have any effect, and neither did MacGuire's hull & deck cleaner, Spray 9, Alcohol Rubs (recommended by the soda supplier), Starbrite hull cleaner, etc., leaving compounding the deck with the equivalent of a 600 grit compound the only material that 'sort of' works, but not particularly effectively. The stains were initially quite yellow in color, and turned to dark grey within a day. I used 600 grit wet sanding to clean the rail area, but this isn't feasible on the non-skid deck. The areas affected are approximately 25% of the horizontal surfaces above the rail line. The hull is mostly ok as they hosed it off as they went. Has anyone seen this and found a solution? Your feedback is much appreciated,
Cheers,
Barry (currently not so cheerful)
Cheers,
