A half knot over a long haul
I agree that a little bit can make a big difference in some cases...reducing speed, say, under power, by a single knot with the idea in mind to get a better fuel efficiency or range over a 24-hr period with a max hull speed of 7 knots will add as much as 4 more hours to the proposed arrival time...provided, of course, there's enough fuel for 4 additional hours!!I think, tho, there are other considerations than a 2-blade v. 3-blade prop that are likely to impose more of a speed penalty than a single extra blade. I wonder, too, whether the folding/feathering prop debate considering the costs and maintenance required to keep the prop fully functional is valid. Here in the salt water of Galveston Bay, I can assure you that even the most rigorous efforts to the contrary still result in some bottom and prop fouling, ergo, additional penalities to speed, so that's why we all go over the side every few months with wire brush and chisel in hand to do a little bottom maintenance.Your points are well taken.
