Too Much is not enough
Being a displacement hull,Mac25s do not respond to added horsepower the way powerboats do. You soon reach a "ceiling" which requires a massive increase in power to break through. At about 10 hp you have as much power as you can use, provided you have matched the motor with the correct prop. The prop on most short shaft 15hp motors have a pitch to provide a speed that would be suitable for a power boat. Useing that prop is like trying to drive a car in too high a gear. the result is sluggish performance, poor economy and possable prop cavitation.Add to that the extra weight and trim problems and you start to create other problems. A 10hp is about top end and if you can find a used Honda 10hp long shaft, it also has a charging coil to charge your battery under power. Remember that a Mac25 is a sailing platform and that weight, balance and economy can all affect the enjoyment of sailing.Good luck with whatever you end up with.Mike
