well, Mainesail, my mileage has varied as they say. I have used Hydrocoat for two years and I roll on a very thin coat with a 3/16" nap roller. My observation last fall after the first season was that most of the paint was gone as it should have been. After my season haul-out this fall I will be able to see if the paint is ablated like last year. Maybe there is something wrong with this year's paint?Not so much in the growth department, that has been okay except for some slime, but it has no slime blocker, but this is very much a hard type paint compared to an ablative.
The tech support department simply lied to me about how this paint actually worked. I was told it was identical to Ultima in terms of how it abladed and that could not be farther from the truth. When my diver cleaned it there was NO sloughing and NO cloud in the water. I paid for an ablative paint to avoid buildup and that is NOT what I got. Buyer beware. I can see why Sea Ray installs it on all their 30+ knot boats.. It does NOT wear away like a real co-polymer ablative..
Yes, PS was still singing the praises of Hydrocoat this spring. That, and ease of application was the reason I purchased. PS does not evaluate ablative characteristics however.I bought, and used, Hydrocoat based on the comments and ratings made by "Practical Sailor" a few years ago. I don't get PS anymore so does anyone who does know if they have changed their rating of this paint? I have been "generally" happy with this paint as I have had no hard growth below the waterline for the past 2 seasons. I have had slime, but expected that as there is no slime inhibitor in the paint. I apply only one thin coat each spring with a 1/4" roller.
That is what I would expect and I get nothing...:cussing:When I clean my water line I end up lightly scrubbing some of the bottom paint and in previous years that has resulted in a cloud of paint. I can't say one way or another if that is the case this year. I will pay attention during my next cleaning.
My growth has just been slime but it does not have a slime blocker so I expected that... The waters are colder up here though...In short, at least for last year, the paint did ablade as I would have expected. My complaint is the excessive growth this year in the form of blooms on the surface of the paint- not slime, not hard growth, just soft blooms.
Your diver should not be intentionally scrubbing your anti fouling paint off into the water, at your request or for any other reason. Intentionally removing paint in preparation for a new bottom is a job that should only be done in the yard, where the waste can be handled and disposed of properly.I am going to have my diver scour it with a green Scotch-Brite in-water, a second time, to get as much off as I can so I can go back to Ultima SR.
Your probably right..Your diver should not be intentionally scrubbing your anti fouling paint off into the water, at your request or for any other reason. Intentionally removing paint in preparation for a new bottom is a job that should only be done in the yard, where the waste can be handled and disposed of properly.
For the same reason you shouldn't discharge your holding tank overboard even though your local sewer system may put many thousands of gallons of waste into the water; because it's the right thing to do.Why should I, a single boat owner, be held to a higher standard than a yard who pressure washes hundreds of boats a year into a small cove?
I speed too, just like the police...For the same reason you shouldn't discharge your holding tank overboard even though your local sewer system may put many thousands of gallons of waste into the water; because it's the right thing to do.
