Don Prior
I have a H37C, 1984 model. I am begining to have water tank problems similar to those described here. I have no problem with cutting the top of the settee off as I have repaired fiberglass before when dealing with the holding tank (which is also due again).My question to Ed Schenck is "how are the tanks secured under the settee?" I have checked your referenced photos which are great for the cutting part. How were your tanks secured? Did you have to cut up the tanks to get them out or did they come out as one piece?Obviously the next question is what did you repklace the original tanks with? I have seen adds for various plastics, welded plastics, molded plastics, etc. Are there "standard" non-mental tanks that will fit the H37C? Where do I find them?Thanks Ed. I follow all your remarks on this site with great interest. You obviously have more time than I do but I am not afraid to tackle a serious project and after owning my boat for 20 years I have done a few. I do not see this as a serious project unless those tanks are mounted directly to the hull and need to be cut out. Otherwise it is just a replacement with new fittings and then put the settees back together.Fair winds.Don
